Tuning keywords
3217 Vistas
Hi guys a bit of a random one here, but I'm trying to slowly start a tuning company but am really struggling with internet keywords. Whenever I look on uk search it comes up with the more generic oem ecu flashing whenever you put in anything to do with enf=gine tuning or mapping.
If you put efi engine tuning it comes up with very little except training companies especially this one.
Any ideas?
What are you searching for?
Im looking for keywords that others will search for to find efi engine tuning rather than generic oem reflash.
What is it you want to know I was meaning?
Sorry Chris but I thought my original post explained that: keywords others would enter to search for efi tuning services.
I think terms like "Dyno Tuning", "Dyno Services", "Performance Tuning", "Engine Tuning", "Engine Mapping", "Engine Calibration", (also ECU instead of Engine) -- for you UK folks "Rolling Road Testing".
I think the reason you find more OEM flashing, is that the market is much bigger for that low-cost option. The challenge is to get those folks that want increased performance and supply them with a complete solution (ECU, wiring, tuning) that does things they can't do with an OEM ECU.
Good luck with your business. I think you will get more business by building a good reputation for excellent work and outstanding customer support, than by SEO marketing.
Absolutely David - Thank you. But of course I need to get some work in the door initially.
