Tuning or bigger diesel injectors
1176 Vistas
Hey there, I'm just curious on where I would start when writing a tune for bigger than stock injectors, thanks in advance
Hello, it will depend on what other modifications are being supported at the same time if no mods have been done then working out an approx amount of fuel to take out is a good start. if you have added mods then the bonus of just adding fuel to suit, A lean diesel mixture generally just restricts power so no harm can really be done whereas a rich mixture can cause detonation and engine failure pretty quickly
we have a webinar coarse that covers diesel tuning
https://www.hpacademy.com/courses/diesel-tuning/
well worth the money if you haven't already done the coarse
Regards Ross
