turbo speed borgwarner link G4
2227 Vistas
translator. hi everyone i managed to wire the turbo rpm speed sensor on DI 4. at this point I would like to activate a safety control strategy for the turbo revs, so as not to destroy it in case an intercooler pipe breaks. could someone kindly help me. the ecu is a vipec 88 LINK G4. Thanks in advance
It is really up to you. You can put the turbo speed on the axis of a gp limit table, on the axis of a boost control table or use it with a virtual aux to say switch on an alternative MAP limit, RPM limit, change boost target etc.
translator . I appreciate your advice, but if you could give me some illustrated examples I would be grateful. I am Italian and with the explanations in technical English on the tutor of the link g4, I am a bit in trouble, I would not want to cause disasters. thank you
