Turning Alcohol
2001 Vistas
Hello,
i'm starting a new project with tuning alcohol. i need to now what fuel pressure and injector size i need to use.
engine 600cc
cycle 4
number of injector 8 (two per cycle)
compression is 15.0 to 1
What size injectors does it have right now? What else has been done to the engine? This is a motorcycle?
The EAT255 and they flow 225cc at 43.5 psi. The secondary injectors are grey part number EAT256 and they flow 460cc at 43.5 psi.
For now I have just put in high compression piston. And degree the cams.
