Two 12 Ohm injectors in parallel driven by low impedance inj driver ?
1966 Vistas
Would it be feasable to drive two 12 Ohm injectors in parallel, using a six Ohm low imedance driver, in order to overcome a certain ECU's output channel limitations (otherwise having to give up sequential ingnition due to the lack of output channels)? Given they are mounted in the same lcation, aiming to spray on the intake valves.
I cannot see any reason why this would not work, but maybe I am missing something?
You don't need a low impedance inj driver to drive two injectors in parallel. It's only needed when you have to limit the current.
You can drive high impedance injectors pretty much as many as you like in parallel on a "standard" output.
Thank you for sharing your knowledge, much appreciated.
