Upgrade Injectors capacity
2615 Vistas
Hi,
I built a new Turbo System with BMW E46 M43 1.9 Engine.
Everything is ready and I want to increase the fuel qty injected using bigger injectors (I install a piggy), what are my options?
I consider adding more injectors but I think it will be better to jest fit bigger injectors.
can't find injectors that fits my engine, where can I get injectors for my engine?
Thanks
Vafner
Almost all injectors fit your engine. They are standard and 14mm oring style with a ev1 plug.
What fuel are you using?
How much power do you intend on making now and final goalsl?
How are you planning on controlling your larger injectors?
