VCDS or VAGCOM
3122 Vistas
Has anyone used VCDS for tuning? It looks very complicated compared to other platforms. Looking to tune my VW Amarok.
VCDS is used for diagnostics and module programming. As far as I am aware, its not used for tuning (unless someone has written custom software for it.)
They are the same thing, and no, you cant use it for tuning. It's for diagnostics and long coding,etc.
