VF HSV MRC delete , removing 140 km/h limiter
4638 Vistas
Hi guys.
I have a 2014 HSV GTS. It has had the MRC suspension removed (now has BC gold adjustables).
The vehicle is now limited to 140 km/h.
This is not quite why the owner bought a supercharged LSA lmao
How do I remove this 'MRC fail' speed limiter.
I'm using HP tuner MPVI2
TIA
Brad Roberts
Just Commodores Limited
1033 Links Road
Waiohiki RD 3
Napier 4183
New Zealand
Hey Brad Did you manage to sort this out with hp tuners ?
Here are the two files before and after I changed the limiters , you can load the original one , then load the 'no speed limiters' one as a comparison , then choose 'show comparison log' CTRL + 5 , and it will show you the differences
  • 2014-VF-HSV-GTS-HPR-enhanced-no-speed-limiters.hpt
  • 2014-VF-HSV-GTS-HPR-enhanced.hpt
Hi guys , is any programing required with tis as well? I have a vehicle coming in today
