vq35hr trigger Link ECU
2315 Vistas
Hello. Does anyone have a Linkg4+ trigger setup for this motor?
I just checked with link and there isn't currently a trigger mode for this engine. You're in luck however as it will be added in a firmware release that's due out in about 3-4 days. Keep watching Link's site for this firmware release.
Never thought I can be so lucky ))
You are lucky as i had to work hard with making mistake at getting mine to work earlier this year with the prototype firmware. Got it tuned in June and almost everything went well. Got about 460whp/390wtq on low boost.
The only issue is i couldnt neither my tuner @Sasha from OnpointDyno to get the PID from the exhaust cam solenoid to track properly. They were somewhat acceptable but noticely unstable.
