Water Meth Solenoid Setup
2768 Vistas
Hi all and thanks for helping me out
I have a water methanol kit from snow performance including a solenoid.
I want to run the whole system by my ECU and pmu. So the solenoid will be connected directly to a driven output of the ECU and directed by a pwm signal.
Question: which frequency should I use for the solenoid and which duty cycle to start?
Of course the dc depends on the boost I am running...
Thanks for giving advise
Phil
In my experience with the Snow solenoids, 30hz is a good place to start.
