wheel speed sensor configuration
928 Vistas
Hi,
I’m currently setting up the rear wheel speed sensor of my BRZ using the ECUMaster Wheel Speed to CAN module (the front wheel sensors are not connected). The sensor is a 2-pin type, and when I measure the resistance, it reads 15 kΩ in one direction and no value in the other direction.
Does this mean it’s a Hall effect sensor?
Below is the ECUMaster configuration interface — could anyone please advise how I should set it up?
Hi, thanks for the reply. There is a positive and negative input on the speed sensor module. I believe I should connect the signal output from sensor to positive pin on the module, but what should I connect the negative pin to? Ground?
And I can choose for a pull down resistor in ecumaster's software settings, does it mean I don't have to physically connect a resistor between signal output pin and ground?
