When tuner has put password on ecu can it be unlocked?
14 Vistas
Hi, i have yamaha R6 and tuner has put password on the ecu and question is can it be unlocked because no clue who the tuner was?
It really depends on the ECU. Generally, they're designed not to be cracked and a full reset and start from scratch is needed.
