Where has step 5-c gone????
1436 Vistas
Question directed at hp academy team..... So trying to watch step 5-c of the hondata worked example and being met with a screen that says this module not available as changes are being made. A few questions... When will I be able to watch again please? And what was wrong with the orginal? How is it being improved? Many thanks
Hey Sam, we are going to reshoot this as we had a mix up with some of the screen casts. Basically the screen cast that was used in the module showed the parameter I was altering remaining fixed and we felt this would introduce confusion. We will have it back online as soon as we can. Sorry for the inconvenience.
Sweet mate good to see that any issues come up you dont hang around sorting them out.
