Who know CAN control pwm power output module where to buy?
1265 Vistas
Hello, Im ready purchase CAN control pwm module for Low pressure fuel pump.But Maxxecu is sold out.
Anybody know who has sell simular products?
https://www.maxxecu.com/products/accessories/maxxecu_can_pwmmodule
Are you looking for a PWM device or will an simply ON / OFF device be sufficient?
I know you mentioned the PWM controller from maxxecu, just making sure.
@DynoDom
PWM device control by CANBUS.
https://www.summitracing.com/parts/fue-72003#overview
Control via 0-5 volt output. You will not have to struggle with CAN addressing from a different manufacturer.
http://www.kaizenrelay.com/
hoping to try these out soon
@Kesterj
Looks like its a good solution.I will ask them how to program the module ,thx!
