Wideband and EGT
2072 Vistas
Hey all! Question that has been keeping me up at night, besides the meaning of life and how to understand women, is about Wideband and EGT sensors. I have an EMU black that I am in the process of preparing wiring diagrams, and all that jazz (currently doing the intro wiring course). The EMU black capabilities of running a single 4.2 or 4.9 sensor. My car, Z32 Twin Turbo swap, is essentially 2 3 cylinder engines that share a crankshaft and utilizes a balance tube on the plenum to ensure equalized pressure. I know 2 sensors would be the best way to do it, and understand the reasoning behind. This is a street car, not going for records, just a fun ride. Can the WB be installed in say, the X pipe, to read overall AFR and utilize an EGT in each bank for monitoring of possible lean or rich conditions? Or am I relegated to adding more electronics? I am trying to KISS it (Keep it simple stupid) :) Thanks all! I appreciate any and all info!
Either put the sensor where all exhausts are merged (ok with an "X" type, probably not a good with an "H" type crossover), or just put in one bank, and assume the other back stays in sync. I've tuned a few cars with only a single sensor, but often end up adding a second sensor just for the diagnostic info. such as where is that mis-fire coming from, or is one back suddenly running lean due to a clogged injector.
