Win pls: EPA 10 paccar mx13
1840 Vistas
Can anyone assist me? I need to download calibration from Ecm to work with and I am not sure if magic tuner would work for what I need?
Win ols course was dealing with obd2 tools and I need something to work with hd trucks. I hope this is the place to ask, thanks in advance for any help!
I have an engine in a truck that has been deleted. The truck will start fine when cold but seems like it is not getting enough fuel when starting hot. I need some help in identifing the cranking fuel map in ols if anybody can assist? If not maybe a signature of what one would look like? It should have barometric pressure and coolant temp as the axis.
