Winols or ECM Titanium
2647 Vistas
Winols or ECM Titanium which is better for a beginner?
With winols you have full control, but you need to have mappack or damos to identify maps correctly(at least for a start). Ecm titanium you only see maps that are available in your map 'driver'. These are usually incomplete or sometimes maps are identified wrong.
If you are willing to do some learning, i would choose winols.
