Would appreciate some Feedback on my afr chart table
1866 Vistas
could I get some feedback on this afr table that was given to me in my base map for a Toyota 3sgte 2.0l turbo stock turbo forged block max intended boost pressure about 1 bar Thanks
I would strongly advise against leaning the engine out with boost/RPM's rising (middle and top right part of the map), more like the opposite!
I was saying it looks Risky to start with going into boost ........ it looks lean in truth
