WTD Motec pro log from m1 ecu
1696 Vistas
Hi, random request, but would anyone have a pro log from an M1 ecu that they're willing to share?
What exactly do you want to do? While I don't have Pro-logging in my M1, I do have a C185 with Pro Analysis, and there are lots of M1 channels included in that data.
I just want to have a play around with pro with some m1 data... I suppose it doesn't have to be from an m1, but they seem to have lots of channels etc. The C185 data you mentioned would be nice if you're willing to share any. Something with gps, lat and long g's, brake pressure and even steering angle would be good as I want to look at driver/lap time data.
Cheers,
Shane
OK, I was going to send you a file of the car running on the dyno, but the GPS data is not that interesting. Here are three laps of Mid Ohio from the 2016 SCCA Runoffs. I think there are something like 90 channels logged there.
Enjoy!
  • MidOhio2016RunoffsRaceFerguson.ld
  • MidOhio2016RunoffsRaceFerguson.ldx
Thanks very much David!
