Zx14r burning coil
1719 Vistas
I got a turbo zx14r. I'm using a mircosquit v3. Bike keeps burning the coils. I'm using a quadspark ignition module N im using IGN1 IGN2 WLED ALED. The ignition output I think is the problem. Any idea?
I'm not familiar with that ignition module but if you're burning coils out then it's very likely your dwell settings may be too long. What have you got in your dwell table?
