1JZ-GTE piston deck height and head gasket thickness
12 Vistas
Im trying to figure out the allowable amount the piston can measure above the deck height of my 1JZ-GTE VVTI to ensure my OEM MLS head gasket (1.3mm) will be sufficient
I have CP Carillo pistons that should suit 9:1 compression ratio and 1.338” compression height, Waiting on a deck bridge to arrive but have measured around 0.0055” using a make shift dial indicator setup
What are some thoughts and clearances people suggest?
Normalmente respondemos en un plazo de 12 horas (a menudo antes).
¿Tienes problemas con el sitio web?
¿O necesita contactarnos por algún otro motivo?
