4G63 NA build
3020 Vistas
Hello everyone,
i picked up a working 4G63 NA block to build because i'd like to keep my stock block 4G63T that is currently in my evo.
With doing the modifications (pistons, rods, studs, machining oil squirters, cams, ...) can this block be as good as the 4G63T variant?
I changed my goals and with the H-Tuff rods and Wiseco 1400HD pistons i'd like to be around 600WHP.
Thank you for any information.
I use NA 4g64 blocks all the time - not a problem... 4g63 should be even stronger as it has more material between the cylinder walls (86.5 mm bore vs 85)
@Georg1970 thank you for your input, it's greatly appriciated! :D
#THANKS! :D
