4G64 with 63T 2G head build comments on my build plan please.
1750 Vistas
Hi all,
I have absolutely destroyed my 4G63T in my EVO7 and I am starting the process of a new engine build.
I have decided to build a 4G64 up. I have sourced a 4G64 7 bolt, out of a magna, and have had the block and crank checked out, and these are good to go.
Ultimately I am wanting to build a dedicated grass roots racing circuit car, with a focus on enduro's. After driving a friend 4G64 build (he purchased the car with it) I prefer the extra down low torque and drivability of his 4G64T over my original 4G63T. Not chasing massive power, just after moderate power but a huge focus on reliability, and planning on flex fuel, E85 for sprints and pump 98 for enduros.
So the plan thus far,
BOTTOM END (4G64 Block and Crank)
Pistons - CP SC7262 Pistons with upgraded 9310 pins
Rods - Manley 14020-4 Rods with ARP 2000 bolts
Main Cap Studs – 8740 chrome moly ARP 207-5401
Bearings + Thrust washer – ALL ACL Race
Balance Shaft Delete – GSC Kit
HEAD BITS (EVO 8 Head)
Head Studs – 8740 chrome moly ARP 207-4203
Inlet Valves – Manley 11160-8 34.5mm
Exhaust Valves – Manley 11161-8 31mm.
CAMS – Stock Evo 8 Cam
Valve Springs – was thinking KVS63-BK Kelford
THE REST
Gaskets – Nitto Gasket kit (no Head Gasket)
Head Gasket – Need advice here.
Adjustable cam gears – Brand not decided on yet.
Harmonic Balancer – Fluidampr
Injectors – Denso/Sard 800cc injectors
Coils - COP kit haven’t pick one yet.
Very good idea. I have built a couple of those lately and I love them but I'm running Automatic transmission...
