Hey, has anyone successfully set up a 13bt with an FC CAS to run on an emu black?
I have been through every iteration of trigger setting I can find, but it won't start. Timing seems to be locked at about 45* advance (if it doesn't drop out), and I can't get any trigger info on the scope. I can get trigger info on a picoscope at the ECU pin header though. I've tried almost every adjustment/delay/filter/tooth combo the software allows but still no success. The software does show trigger sync and rpm during cranking.
The engine was running fine on the old Ems stinger before I installed the Black.
Any basic start up info would be much appreciated.
Post your map or at least trigger settings.
FC CAS should be 2 VR sensors, no pull ups.
Are you using a timing light on rotor one trailing or lead?
Attached is my last saved map, although it is not indicative of all of the changes I have been through.
Timing is locked on this map at -5 to align with L1 timing mark, using the timing light (non adjustable style).
