sr20ve cam timming with 16ve cams
1914 Vistas
HI guys
Can anybody help me dial in 16ve cam sharfts i need specs for cams.i have 7.1 at 200deg for intake and 7.95mm at244deg .needing timming eg 19dec before tdc .what should this measurment be.thaks in advance
What are you trying to do here? Are you fitting stock SR16VE cams to an SR20VE head? Is there any reason you can't dial these in on the factory marks? It's notoriously difficult to get solid data on factory cam timing which isn't going to make your job any easier. Personally I'd recommend starting with the factory timing marks and then try advancing and retarding the cams on the dyno to see how the power responds.
