WHP-PNP-2jzvvt adapter
1144 Vistas
Excuse this complete noob question but, I have acquired this adapter for 30 bucks so I did not want to passs it up. I know many say do not use but wire directly to your harness. But this is my reason why I wish not to do, and I have a question as well. I have 2 different JZ motors, with the stock harness, I would like to bounce back and forth with. But I have the EMU classic I am trying to use with these motors, and before I have to splice both harness seperately, can you make this pnp work with the classic. EMU site does state only works with the the black, I figured there has to be a pin out for the PNP harness to just move wires around. Thanks for giving me a second to read this but wanted to see if this is even an option of working correctly with the classic. And if someone had a pin out of the pnp adapter for the 2jzgte vvti.
ecumaster.com has all the pinout in there database (google drive); bottom of the downloads page
If it's Black only and a VVTi JZ, its probably DBW which isn't supported by the Classic, at least directly.
