Assembly Tutorial
Modelado 3D y CAD para deportes de motor
Discusión y preguntas relacionadas con el curso Modelado 3D y CAD para Motorsport.
1388 Vistas
Is just me or is everyone having issues with the screen being to blurring to read from around 5 minutes
checked from my end and everything looks fine.
Sounds like a connectivity issue, or check your quality settings on the video and make sure it's staying in HD
Check this post out too Terry, hope it helps: https://www.hpacademy.com/blog/course-video-playback-optimisation-vimeo/
Another cause we have found that can cause a similar issue is if you are using mobile data and your speed is being choked/throttled, but by far the majority of issues are to do with the browser and covered in that link above.
