Debate y preguntas relacionadas con el curso de Modelado 3D y CAD para el Automovilismo.
When following the tutorial I ran into this error "
The given path is not tangent continuous around tight corners. To make self-intersecting sweep work, the circular path segments should be tangent continuous to the adjacent path segments." I'm not sure what I did wrong?
Jake, In your second sketch for the line you have do you see the tangent constraint identifiers? They would look something like this..
Is it very easy to draw circles and arcs and miss the tangent "snap". Since this feature wasnt clearly defined in the module, "..then we just click, hold and drag to make an arc at a tangent, placing two in an S shape....".
