Rear drum brake simulated data in Brake System Calculator
Diseño y optimización de sistemas de frenado
Módulo correspondiente: Diseño del sistema de frenos > Calculadora de frenos HPA
Debate y preguntas relacionadas con el curso Diseño y Optimización de Sistemas de Frenos.
823 Vistas
I would like to retain the rear drum brake in my brake system design calculations. Are there any figures that could be put into the calculator that would give representative output in the calculations for the data below.
Drum diameter:180mm
Single brake shoe size: 173mmx25mm area 4325mm2. Two per drum
Slave cylinder single double ended bore size: 17.5mm
