1JZ VVTI Lamda Target
Comprender el AFR
Debate y preguntas relacionadas con el curso "Comprendiendo AFR"
3413 Vistas
Hello from Switzerland,
I am currently working on my Jzx100 1jz vvti engine and will be mapping the engine from scratch.
In that respect I would like to know your reccomended lamda target values. My engine will run up to 1 bar of boost for the moment.
I have a power fc ecu and I will be using the FC commander Pro software.
Have any of you ever used it?
Thanks in advance.
Best regards.
Jesse
Within the course we do offer suggestions for safe starting AFR targets that you can use. For a boost target of 1 bar, I'd be suggesting you start with a lambda target around 0.80 and test to see how the engine responds.
