AFR
Comprender el AFR
Debate y preguntas relacionadas con el curso "Comprendiendo AFR"
3502 Vistas
How to know that the AFR actual is equal 12.5:1 as mentioned above in the video?
You will need a wideband meter or input to the ECU to measure the air fuel ratio in the exhaust.
