afr or lambda targetted?
Comprender el AFR
Debate y preguntas relacionadas con el curso "Comprendiendo AFR"
1976 Vistas
at 00.50 , are we talking target afr or target lambda 0f 0.8 to 0.82? Great courses btw , learning a lot !
Hi Blair, if I'm mentioning a value of 0.8 to 0.82 then this is a lambda value. If you can you link to the specific module you're watching then I'll make sure I haven't overlooked something in the module.
