Air Temp Compensation
Comprender el AFR
Debate y preguntas relacionadas con el curso "Comprendiendo AFR"
2233 Vistas
In your video you apply 0 Correction to 20 Deg Celcius.
In your attached example 3D Temp correction table 0 Correction is set to 0 Deg C !
A little bit confusing to me !?
Can you post a link to the specific video in question, please?
Also, unusual car as your id - is it the 4 or 6 cylinder version?
https://www.hpacademy.com/dashboard/courses/understanding-afr/fuel-compensations-air-temperature-compensation
As the name implies 914/6 GT it is a replica of the 1970 LeMans Porsche Race Car with a modified 6 cylinder 2,8 l engine and changed from carburator to EFI.
