Target afr table for Turbo application
Entendiendo AFR
4496 Vistas
Good day Andre,
I'd like to know how does the target afr table differ from the example given in the course for N/A applications. Do I go rich from as early as 80-100kpa right up to my desired positive boost level, as well as higher RPMs??
Target tables will differ depending on application and what the vehicle is being used for, there is no set number/target table and each engine has to be tuned to what it wants. That being said I suggest checking out the webinars below to help with a good place to start
https://www.hpacademy.com/previous-webinars/066-planning-your-afr-targets-forced-induction-engines/
https://www.hpacademy.com/previous-webinars/065-planning-your-afr-targets-naturally-aspirated-engines/
Thanks Chris!! Much appreciated
