Air flow question
Fundamentos de aerodinámica
Debate y preguntas relacionadas con el curso Fundamentos de Aerodinámica .
1022 Vistas
I have a mid engine Fiat x19, and Im changing the air flow path exiting form the radiator form under the car to out the bonnet or hood... What`s a better option
1. air exits bonnet vents and is aimed at the windscreen
or 2. the air is aimed at the left and right sides of windscreen.
some things to consider are,
the motor air intake is above the roof and will the hot air from the radiator make any difference to in take temp?
How big should the vents be? is a bit smaller or bigger better?
where should the vents be? closer to the windscreen or the front of the car?
anyone out there?
