adjustment via lower collar or via spring preload
Fundamentos de la alineación de ruedas en los deportes de motor
1495 Vistas
I've never heard of this way of compressing the spring for ride height adjustment is it because there full race coil over. usually you just preload the spring 4mm and user the lower collar for. ride height has anybody done this way in the.video totally removing the spring to get ride height. preloaded the spring and use the lower for minor adjustments?
