Centre Cap Adapter for Camber / Caster bubble gauge
Fundamentos de la alineación de ruedas en el automovilismo
Debate y preguntas relacionadas con el curso Fundamentos de la alineación de ruedas en el automovilismo.
2245 Vistas
Hi RaceCraft crew,
Are you able to share any further information on the Camber/Caster bubble gauge adapter you had made for your alloy rims?
Can you share any photos of the back side of the adapter?
I would be interested to see how you maintain a positive engagement in the rim without the weight of the gauge pulling the adapter out of the rim.
I cant be sure what the racecraft guys use, but it looks to just be a steel puck. Aslong as theres some depth to it, the weight of the gauge should try to rotate the adapter not pull it out horizontally, so a snug fit on the adapter with... i dunno, an inch or so depth should keep everything tight as you turn the wheel.
If you have issues something like https://i.imgur.com/dBZjdpD.png could be custom made to locate against the wheel and something in the hub.
