Spring rates
Fundamentos de la alineación de ruedas en los deportes de motor
Módulo relevante: Fundamentos del diseño de suspensiones > Tarifas de primavera
837 Vistas
Thoughts on spring rates for a C4 1986 Corvette with coil overs used for track days only
Thanks, Nick
Double adjustable shocks…
There are Corvette specialist who will be better able to advise.
But you should have details like track characteristics - surface - tarmac/seal or concrete, or a mixture of old and new tarmac; bumpy or smooth; fast or slow corners or both; what tyres you plan to use; what engine and transmission are you using - that will affect the weight balance; etc ready to give them.
