Aligning piston ring end gaps
2669 Vistas
Placing comp ring gap on a thrust face, won't do that damage the cylinder especially the major side ?
Ring end gaps should not cause any cylinder wall damage regardless of their orientation.
As David said - remember, piston rings will be rotating slowly in their grooves (unless a 2 stroke where they're pinned) so sometimes they will be there, anyway, sometimes not.
That rotation is also why I, personally, don't bother with their placement - some may have their own ideas on that, though.
Any reason you have a concern?
