Debate y preguntas relacionadas con el curso Fundamentos de la puesta a punto de motores diésel.
As it is said this course is for tuning modern common rail diesels, but will this information make me able to tune my golf 4 101ps pump-duse and is it the same? Thank you!
Hi Teodor, Short answer: yes and no. Your Golf 4 1.9 PD (EDC15P) is actually much simpler to tune than the ECUs shown in this course. The maps are already well documented, so you can use VAGEDCSuite, which has the definitions built in and can also correct the checksum. You don't really need to find the maps yourself. The main difference is that EDC15P is not torque-based like EDC17. Driver's wish, the smoke limiter and the torque limiter all work in injection quantity (mg/stroke) instead of torque. Before raising IQ, check how much air actually gets into the cylinders at your boost level. On EDC15P the MAF reading is logged in mg/stroke (VCDS measuring block 003), so you can compare it directly with fuel quantity. For clean, smoke-free combustion aim for an AFR of about 17.5:1, meaning 17.5 mg of air for every 1 mg of fuel. So the maximum fuel you can burn is roughly: max IQ = actual air (mg/stroke) / 17.5 For example, if you measure 1000 mg/stroke of air, you can burn about 57 mg of fuel without smoke. Set your smoke limiter based on this, not on a number someone else used on their car. When you raise the IQ, you also have to extend the duration maps. You do this by interpolating/extrapolating from the stock duration map, so you know which injection duration (crank degrees) corresponds to which fuel quantity. Also keep an eye on EOI (end of injection = SOI + duration). If EOI gets too late, EGTs go up a lot. Until you have an EGT probe fitted, I'd recommend keeping EOI below 10° ATDC. Always log your changes (e.g. with VCDS) and compare requested vs. actual boost and IQ.
