Debate y preguntas relacionadas con el curso Fundamentos de la puesta a punto de motores diésel.
Hi
Anyone can assist how to modify this map ?
"Desired air calculations" map needs to be modified ?
The Map looks to be a desired airflow based on engine speed an load (fuel rate/cyl). If you've modified the injector on-time (pulsewidth), you may consider modifying this map by similar percentage in the fuel rate areas that match your pulsewidth adjustments. If you have not modified the fuel rate calcs, I'd leave this alone to start.
Nick
Noted with Thanks
