Timing calculation
Fundamentos del ajuste del diésel
Discusión y preguntas relacionadas con el curso Fundamentos de Tuning Diesel
1995 Vistas
Hi Ben,
I would like to know more about the 120 factor than we use to calculate the inj time related to rpm.
Thanks in advance.
Antonio Romanelli
Hi Antonio, the 120 just comes from the calculations we make to turn revolutions per minute into revolutions per second, then converting this into a cycle time. Rather than doing this in a couple of steps we can just divide 120 by the engine rpm and this will directly provide the cycle time at that rpm.
Good afternoon. Is the 120 applicable to any engine with any number of cylinders? Thank you! .
Hi Andre,
Thanks a lot for the clear explanation.
All the Best.
Antonio Romanelli
