Debate y preguntas relacionadas con el curso Fundamentos del cableado en el automovilismo.
Hey I know this is probably a stupid question but I'm getting my 91 obd1 crx with plug and play 6040 v2 aem running and I'm getting 2.7 volts from the ecu d11 (tps signal input) and the d17 (map signal input) out of the ecu. My question is,is that normal and if not what could be causing it. Also tho tps is show ing 100% and engine load is at 35psi on the aem hooked up to the laptop.
Thanks
