Charge Harness Wiring
Fundamentos del cableado EFI
59 Vistas
Hello all, recently I’ve tackled removing the old harness in my 1995 Honda civic eg coupe. Ive replaced it with a new one but still need to make the charge harness for the car. Once I made a harness I buttoned everything up the car won’t crank and the key on functions like fuel pump prime and other things do not power on or prime. I feel like I did something wrong wiring up the fuse box to power because now the ECU does not light up(or I could’ve shorted the ecu when trying to start). I wanted to make a relay panel as well but I want to make sure I figure this out before starting that. I do have another ecu to test but for now I want to fix this wiring. Thank you to anyone who can help.
