My first concentric harness - Non automotive industry.
Fundamentos del cableado EFI
198 Vistas
Hey Guys.
My name is Charles. I'm an ex-car guys and still racecar driver. I have a startup that build radar system for excavator. We need to make a harness to connect both side of the radar. I'm doing it race specs mode because the construction industry is almost the same as a race car.
I need to get 2 Rf cables from one side to the other side of the harness. They are 5.25mm each. I was planning on using them as a core, maybe sleeving them in their own Raychem. My problem is that using 2x 5.5mm doesn’t make a very round core. It looks like a rectangle almost. I can fit a third one and use it as a spare in case of failure. Anyone tried to use 2 big cables as a core before that look like a rectangle ?
