volvo redblock CPS setup and wiring. EMU CLASSIC
Fundamentos del cableado EFI
4283 Vistas
Hi,
im helping a buddy to wire and tune an emu classic in his 940,
Everything is working except the crank and camp position sensors. i havent used a 3 wire hall sensor ever and im not sure how to wire and setup the parameters.
crankshaft sensor 3547847 (oem volvo 940)
Camshaft sensor 0232101023 (volvo 850)
i know that the 3 wires are: signal, ground and positive, but im not sure if this sensor needs 12 or 5v, the major part of the info for these engines is in swedish and cant found anything.
I tried to use the scope function and it doesnt show anything.
Any input is a big help!
Thanks
Hello sorry i can thelp woth the ecu settings but
pin 1 trigger ground
pin 2 trigger signal
pin 3 12v
Regards Ross
The 850 cam sensor is hall effect, however the 940 crank sensor is not, they are a VR sensor.
In the pic below, "Out" is the signal, center pin is ground, "S" is shield.
