VW MK5 example?
Dominio de WinOLS: Identificación y edición de mapas
Discusión y preguntas relacionadas con el curso WinOLS Mastery: Identificación y edición de mapas
2292 Vistas
Hello,
I am at the "Configuring WinOLS" module, and when I open my demo I do not have any demo files. I have jumped around in some modules to see if you have posted the VW file and have not found it listed below. Can we please get it posted here so I can continue.
I have attached a screenshot of the default folder, as well i have searched any folder i have found on my PC.
Thank you.
what are you trying to do? you need to import the stock read of the car. I tried to upload the stock file that he is using but it will not allow me to. leave me your email. I might have a full mappack for it too
I'm trying to follow along with the modules, I have WinOLS v5 Demo, but I cant follow along without the file. I don't know if WinOLS or HPA was supposed to supply it. Id like to move forward with the learning. I see a couple posts down another seems to also have a similar issue with not having the MK5 file for the course to follow.
Info@essential-performance.com
Thank you
Hi Stephen, apologies for the confusion. I'll get the team to add the file to that module however you can download it from this module (https://www.hpacademy.com/dashboard/courses/winols-mastery-map-identification-and-editing/winols-practical-skills-finding-and-defining-maps-2d-maps) so that you can work along side the configuration module. You'll find the file at the bottom if you scroll down.
I hope that helps.
Stephen Wilson i emailed you the stock file for the course.
Thank you both Andre and Brian!
