Haltech E8 Autotuned
Impresión 3D práctica
Discusión y preguntas relacionadas con el curso Impresión 3D Práctica
2343 Vistas
G'dayI have an E8 ecu. I have wired in a Innovate LC-2 wideband sensor and controller. It is setup correctly and works in fine o2 closed loop fuel mode. When I use this feature on the main fuel map, pressing the Q key it keeps adding 30% fuel. does not matters what I do. Target AFR table is setup correctly. Any ideas?
