Determining Chanel Current Limits
Instalación y configuración de PDM
1685 Vistas
Hello,
The Determining Chanel Current Limits module is also missing the linked documentation... although from the description, it sounds like the same document as in the previously mentioned module.
I think they may still be updating this course. The closed captions and log for all the modules past "Logical Functions" aren't there yet either. I find it helpful to watch with CC turned on to help reinforce retention of the information in these courses.
Is there any specific query you have, and do you have a specific PDM in mind?
Different PDMs, and their channels, will have different current limits for different outputs/drains, which should be in their documentation.
