Help for wiring and configuring this setup
Instalación y configuración de PDM
Módulo relevante: Pruebas de banco > Freno de mano eléctrico y motor del limpiaparabrisas
1660 Vistas
Hi Andre
I am trying to copy this setup of yours, handbrake.
Not for a handbrake but for a small DC motor to shift brake bias, front or back.
I do have the following components already working in the car;
1812 Dash
PDM 30
15 button keypad
DHB
10 Button and 2x Rotary 8 step on steering wheel
Could you perhaps share how to wire and configure in detail?
Thank you so much in advance.
D
What are you using for positional feedback for the balance bar?
Are you wanting it to move in discrete steps, or just drive in one direction depending on which button is pushed?
Hi Stephen
Unfortunately there is no position feedback within the DC motor nor is it possible to mount a hallsensor on the pedal assembly.
This leaves me with only the option to apply voltage to the motor and have the PDM turn off power once the motor reaches higher current at the two ends of the travel.
D
